1 - 4 of 4 Posts
Trying to change valve cover gasket, 94 v6 Camry, by firewall. Will someone help me with steps to move the harness out of the way? I'm having problems with finding the fasteners and releasing the harness at timing belt #3. Any help at all!
It's kind of hard to explain where they are. There should be 5 bolts on that side and the clip on the timing cover should just have to be pryed off with a screwdriver. If you have break it, just get another or jury rig it.
Discussion Starter · #3 ·
Your info is good. I found out you need to know which way to pull and shove, and then out rassle it. The pro's also remove the harness studs with a reverse torques devise. I saw an ad in Craig's List. "Unemployed certified Lexus-Toyota Tech.........He drove 50 miles to do all needed work and put my car back together. I must be livin right!
1 - 4 of 4 Posts
