It is the end of 2020. Happy New Years and stay safe out there. Today, I am like many on here cleaning shop as the new year arises. Some of you may wonder what you will be doing in the following days. Maybe it is to improve...
Good luck.
Post #2 Coolant flush + Tips
Coolant on our platform lasts well over 100k. It is good practice to change it a little more frequently than prescribed. I maintain my coolant by topping off with Distilled Water only when low. Others do so with 50/50 premixed coolant.
I went ahead to drain the coolant into a leftover empty bottle.
This is about 80k of use. Still very transparent and no mixing of oil in the bottle. It’s clean.
I did not drain any more from the block and got about one full gallon bottle of coolant. Then, I added fresh distilled water to the rest of the system. Currently still in the car.
One TIP of bleeding the air out of the system is to fill the radiator cap full and run the engine. Over time you will occasionally have to fill it up. Once you’ve gotten up to operating temp with the cap open the whole time you can kill the engine and add more water. At this time the water will cool and contract. Just add until it doesn’t contract anymore. Fill the Reservoir up and run the distilled for a few days. Top off if needed. In my case, nah it’s correct the first time.
Meanwhile, I have purchased a new thermostat and gasket from the local Toyota. Also, we will do injector o rings and gasket, clean the intake manifold, intake runners, and throttle body. All can be done in one session. Some of you are probably like, ohh I see what you did there! Haha
As you guys can see, we’re getting ready for what’s out there in the abyss.
Good luck.
