1 - 20 of 21 Posts
TN's furry friend
1995 Toyota Camry LE
Was thinking about getting a new Magnaflow Tip to cap off my stock muffler. There's a 3 x 7.5 x 2.25 (outlet/length/inlet) and a 3.5 x 4.5 x 2.25 one. Both are double wall with an angle cut.
So what i wanted to know is if the 7.5 inch one is too long. I measured the stock tip and it's almost 12 inches from the muffler. I thought it would look weird but iono, give me a second opinion, 4.5 or 7.5?
Thanks.
Auto-Cross Addict
Yeah, it would look bad if it was sticking out past the bumper. You want to keep as much to the stock look as possible.
And if you have a dual tip muffler, make sure there is enough room for both of them to fit on without rubbing.
The Pilot jobbers aren't that bad man, just get a stainless one... costs more... and has a little less BLING to it so it looks a little classier. As far as sound goes, no difference, but be careful as they mount with 2 or 3 brackets (depending on how big the tip is) that go through the tip and fit around the pipe... if you bend these clamps and be dumb like I was the tip will always sit sideways no matter how much you adjust it! I was out 12 bucks b/c of that... Otherwise they're good tips, but remember get the stainless! IT's painless!
Steve
Gen5.5 Sportivo V6
04 Camry Sportivo V6
ive got a single pipe muffler, and i got a shop to weld on a twin pipe chrome tip for me :D
but whether you get a shop to do it, or do it yourself. make sure the tip is perfectly straight and aligned at the angle you want it.
because when they welded it on for me. the aligned it to the curve of the bumper :disappoin instead of aligning it straight with the exhaust cut out on the bumper.
so if you look at my car carefully you can see that the exhaust tip is a bit crooked :lol:
initial-T said:
hm...its supposed to make a difference if it's 'resonated' but i'm not too sure really.
If it's sold at Wal-Mart, dont expect too much:D... All you get are some golf-ball dimples inside the tip, no real change in sound...
Steve
Mad Scientist
94 scepter coupe
actually the tips do make a difference.
in my 85 escort wagon i had a straight through exhaust (no cat,resonator,and no muffler) all i had was a 4inch tip that was about a foot long (12inches) and that thing had a deep sound at all rpms btw it was unresonated. i've yet to find another tip like that but yeah exhaust tips do make a difference so choose wisely.
TN's furry friend
Discussion Starter · #14 ·
wow that is one long tip! :D was yours double wall or single? and who was it made by?
you probably had a sound change cuz it was a foot long and 4 inches wide, that is huge
Auto-Cross Addict
Yeah, the tips I was going to get with my custom set-up were 1 1/2 feet long from the glass packs. If they are long, yes they will effect the sound. Because the sound still vibrates within the pipe. That's why you should always make sure and get the right width pipes for your engine.
If you are getting new tips for a stock muffler, they will both right on. Just tighten them on. Just like factory tips :)
Ford Powered
1999 Ford Mustang
i just want a tip cuz the wagon is so high, it need something other than the gross looking stock tip to draw attention away from the big gross muffler.
TN's furry friend
Discussion Starter · #18 ·
if you just want a simple bolt on tip, go to autozone or walmart. if you want something fancier go to magnaflow.com and click buyonline for some online stores. nopi.com has some tips too
Ford Powered
1999 Ford Mustang
yes..for budgety people like me, i just assume pick up a bolt on, until i can get my new exhaust.
autozone/wal-mart have very similar tips, just depends on what u wanna spend.
Mad Scientist
94 scepter coupe
it had no resonator in it you could baisically fit a coke can in it without a problem.
i bought it for 5 bucks from a friend of mine 6yrs ago i'v yet to find another:(
1 - 20 of 21 Posts
