In a 2018 Toyota Camry XLE, can an external mp3 player be played through the USB port?
I use use a thumb drive as the radio will play mp3's. If you use an mp3 player, you have plug in to the plug next to the USB drive. Thumb drives are super cheap and easier to manage with the radio.In a 2018 Toyota Camry XLE, can an external mp3 player be played through the USB port?
Yes, the factory radio in an '18 XLE is designed to use an IPod via the USB plug. I used to use that functionality all the time in my '13 Avalon until I upgraded to a different setup. I don't know if a different mp3 player would work via the usb input. If you already have the mp3 player, give it a try.In a 2018 Toyota Camry XLE, can an external mp3 player be played through the USB port?
I inserted a Formatted Thumb Drive in USB port but NOTHING. USB (Source) is greyed out. What am I doing wrong?I use use a thumb drive as the radio will play mp3's. If you use an mp3 player, you have plug in to the plug next to the USB drive. Thumb drives are super cheap and easier to manage with the radio.
This one is so tiny, you can close the door and not even see it.
SanDisk 64GB Cruzer Fit USB 2.0 Flash Drive - SDCZ33-064G-G35
Buy SanDisk 64GB Cruzer Fit USB 2.0 Flash Drive - SDCZ33-064G-G35 at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!www.amazon.com
it has to be formated fat 32! In a windows computer.That is the one I used
Thanks, that was my problem. Working just fine now.it has to be formated fat 32! In a windows computer.
