I will check the exact method when I get in my car after work. But if you go to the Map and then tap the settings button on the left side, there should be an option called Route Trace or something similar.
I have been following this forum, as I need to make a car purchase - and I have pretty convinced that a 2019 Camry SE would be it. The Toyota longevity is appealing - my brother's (and most recently my nephew's) late 90's Camry, which they bought new, just recently was retired with 300k miles...
Can the lug nuts that are on my aluminum wheels be used on the steel wheels I'm using for my winter tires? The garage installed my winter tires on steel wheels and used the nuts that were on my alum wheels. They said I don't need to use the tapered nuts. But when I checked with the wheel store...
Is there a big difference in power for the two? Was looking into a se nightshade edition just wondering if it has enough power. Currently have a 04 Corolla and it does fine.
Post any pictures of your Gen 8 Camry in this thread!
For info on how to post pictures, click here: http://www.toyotanation.com/forum/63-highlander-hybrid/317883-how-post-pictures.html
WARNING:
This thread has a strict NO CHAT rule. Each post can have text in it describing the picture, but a...
