Can anyone please tell me where the the coolant fan switch is located on a 1998. I am having problems with it running hot in traffic and suspect it is that switch. I have changed the thermostat and thr temperature sensing switch on the thermostat housing and also the fan motor istself (there was a lot of play in the shaft and I didn't want the blades hitting the radiator.) But still having an issue.
I understand the fans operate on a separate switch....
Thank you....
Mike
Thank you....
Mike
