61 - 64 of 64 Posts
my 89 toy p/u when its cold out, 60 deg or below, below 40 deg, idle surge when I hit the brakes, let off brakes, goes to high idle, let it sit 10 mins, idles great, touch brakes and it does it again.
Alright guys need some help, got 92, 3.0 v6 new coil, fuel pump everything seems to be operating correctly, I can crank the truck, while cold it runs great, but after the motor gets warm or runs a while, whether idling or goin down the rd, it just cuts off and a couple fuses in the box in the cab on driver side are pretty warm, the truck had been under water and up above that box, is there a good chance the fuse box is no good any more and it's just Heating up due to corrosion ?
Hey guys,
I've just replaced my timing chain and guides, and everything that goes with it. One of the main goals was also to fix a slight oil leak right up the top of the timing case just above the water pump. Now, while the case was off, I made sure the section of head gasket that is free'd up was stuck to the head with gasket goo, then while I placed the timing case back on there was nothing that could possibly get through.
Left it for a few days to dry before getting everything back on and putting oil etc back in. Started her up, did the timing, and sure enough, the little son of a bitch of an oil leak is back in the same spot. Does anyone else have this problem with the 22r???? How do I fix it :/
I have a problem right now where engine timing is low and needs to be forwarded. Idle is low when not giving gas. But as mechanic turned the idle screw up half a turn, didn't fix the problem. Going to have him forward the engine timing. Problem started as he changed the engine timing to pass smog test.
61 - 64 of 64 Posts
