I own a 2003 CAMRY LE 75,112 miles. I bought new from Toyota. I have taken good care of this investment. At a recent oil change I was told of two issues:
I took it for a oil change and mechanic I’ve been to for many years who is probably 65 yrs old said:
2 ISSUES:
- FRONT FLEX PIPE IS LEAKING. I BELIEVE THIS WILL FALL OFF WHEN DRIVING IF NOT REPAIRED (PER SIMCA MECHANIC). THIS PIPE HAS TO DO WITH THE EXHAUST.
- ENGINE OIL PAN IS RUSTY & SWEATING OIL & NEEDS TO BE REPLACED.
I wanted to get a 2nd opinion and took it to another local mechanic, MMechanic that the neighborhood listserv posts had good things to say by a handful of neighbors.
I had always INTENDED TO KEEP CAR FOR 10+ YEARS.
I told the reception man I wanted to be in the back when the mechanic owner looked at these 2 issues so we could discuss them better. Reception man said I could only come back After mechanic/owner did his look/overview of my car. WAS THAT A MISTAKE leaving owner/mechanic alone with my car, a place I've never been before? Could he have done damage to my
Coolant System Repair (WATER PUMP) thereby creating a leak in my car? Again, first mechanic never mentioned this. Not sure it was wise to have left my car in his hands/out of my sight without being back there the whole time.
When MMechanic owner allowed me in back to look at my car and discuss
it was a bit amazing. He starts up with a Scare orientation, telling me that my car is very bad ALL OVER due to the environment taking a big toll and rusting and corrosion is everywhere. As you can see from the below written estimate, MMechanic found a number of other issues that NO ONE has ever said are issues. I’ve had such little issues w/ this car and I don’t have much experience with mechanics. First off the
Customer Comments Recommendations he wrote at the start of his estimate that you can see below is
a lie. I only went there w/ two known issues as I've stated above. So, he has decided to LIE in his estimate to me, which entirely negates him from ever touching my life again.
But, I need to learn from this bad experience to avoid these types in the future!
He alleges
WATER PUMP has a small leak and this is real bad.
Description Price QTY HRS Subtotal
1 Remove and replace Engine Water Pump -Includes: The removal of
component and all necessary components for access.
2.1 $189.00
2 OEM Water Pump and gasket. $122.19 1 $122.19
3 Extend Life Coolant $25.00 1 $25.00
Tax (6%): $8.83 Total: $345.02
He also says the battery is about to die as it was installed 2013 per a label I did see this label he pointed out on my car battery top corner though I don't ever recall seeing that before yesterday.
HOPE YOU CAN PLEASE SHARE THOUGHTS / RECOMMENDATIONS.
MMechanic seemed like a ‘polished’ sales guy and after reflecting on him I have solid concerns on all that he said. I'm not going back.
Here is MMechanic full quote.
Would like a quote for an oil pan replacement and front
flex pipe replacement up to the catalytic converter. Car has
a myriad of issues going on, will need new brakes up to
5,000 miles left, water pump needs to be replaced. Also
the tail end of the exhaust has a significant amount of rust
particularly where it connects to the exhaust exit pipes.
We can also repair the current exhaust system you have,
instead of replacing the entire component. Battery is old
dates 11/13, makes this battery 9 years old! It will also
need front brakes in about 5,000 miles, Engine Water
pump has a small coolant leak.
Engine Repair (Oil pan)
1 Remove and replace Engine Oil pan and gasket. Includes: The
removal of component and all necessary components for access,
time to add fluid.
4 $360.00
2 OES OIL PAN ASSY - NEW $137.66 1 $137.66
3 OIL PAN GASKET $18.78 1 $18.78
4 TOYOTA OIL PAN BOLT $2.95 10 $29.50
Tax (6%): $11.16 Total: $557.10
Exhaust Repair/ Flex Pipe
1 Remove and replace Front Exhaust Pipe Assembly complete
section. Includes: The removal of component and all necessary
2 $180.00
2 EXHAUST PIPE WITH INTEGRATED FLEX PIPE AND CATALYTIC
CONVERTER ASSY -NEW
$809.91 1 $809.91
3 OES EXHAUST PIPE GASKET AND HARDWARE KIT FRONT AND
REAR
$45.98 1 $45.98
Tax (6%): $2.76 Total: $1,038.65
Coolant System Repair (TOYOTA WATER PUMP)
2.1 $189.00
Created: 12/31/2021
12/31/2021 MMechanics
Page 1 of 3
Battery Replacement
1 Load test, Remove and replace battery, clean terminals. Includes:
The removal of component and all necessary components for
access, and saving Computers memory information.
0.35 $31.50
2 S35 Series 550 CCA EXIDE Battery -New (Two years warranty) $164.89 1 $164.89
Tax (6%): $9.89 Total: $206.28
Remove and Replace Front brake pads and brake Rotors, service calipers.
1 Remove and Replace Front brake pads and brake Rotors, service
calipers.
2 $180.00
2 Premium Front Brake Rotor -zing coated $67.95 2 $135.90
3 Premium Front Brake Pad Set -Ceramics $70.45 1 $70.45
Tax (6%): $12.38 Total: $398.73
Manufacturer Special Policy Adjustment Programs
Federal law requires manufacturers to furnish the National Highway Traffic Safety
Administration (N.H.T.S.A.) with bulletins describing any defects in their vehicles. You
may obtain copies of these bulletins either from the manufacturer or N.H.T.S.A. In
addition, certain consumer publications or organizations publish this information,
which may be available for a fee or for free. NOTICE: Under certain circumstances, the
repair facility may not be responsible for damage to the customer’s vehicle while it is
on the facility’s premises. You should ask the management about the extent of its
responsibility and its insurance coverage.
CUSTOMER'S RIGHTS
1. You are entitled to a written estimate upon request if repairs will exceed $25.00.
Do you want a written estimate? Yes No
2. You may not be charged an amount more than 10% above an estimate without your
consent.
Parts ................................................. $1,560.26
Labor .................................................... $940.50
Subtotal ...................................... $2,500.76
Tax ................................................... $45.02
Grand Total ..................................... $2,545.78
Paid To Date ........................................ ($0.00)
3. You are entitled to the return of any replaced parts except those that must be returned to the manufacturer under a warranty agreement. If you do not
want the parts, Initial here:
4. Repairs not originally authorized by you will not be charged to you without your consent.
I hereby authorize the repair work listed you and your employees may operate the above vehicle for purposes of testing, inspection or delivery.
Signature
Notes
12/31/2021
Below is a link to the quote you requested from MMechanics. Please review and let us know if you have any questions.
Page 2 of 3
File: Quote_4896_-Engine_Repair__Oil_pan__and_4_More-__-_2003_Toyota_Camry_LE.pdf
Page 3 of 3
