Does it sorta looked ribbed?Google it. It is just lots of woven metal straps allowing flex, if that makes sense.
They can.Does it sorta looked ribbed?
Number 7. It's a typical item to rust away.
Mine could be hanging on by a thread 💩Number 7. It's a typical item to rust away.
That's it. Could be better but unless it is leaking then it is no issue. Also seems like it was replaced already.? this i think is the flexpipe on the old Corolla
its not leaking yetThat's it. Could be better but unless it is leaking then it is no issue.
She makes separate threads. She never told us what coolant she bought in the coolant thread and in the other coolant thread her coolant was refused. We don't even know what parts she seems to have bought.OP sure got everyone beating their keyboards to death and hasn't been back in 9 days.
Pretty sure she got things figured out on her own!
FWIW, OP has been on the forum, just not back to this thread!
Its a learning process!OP sure got everyone beating their keyboards to death and hasn't been back in 9 days.
It's flexible.Its a learning process!
If that flexpipe pic ii posted is supposed to be flexible I touched mine and it felt all brittle, probably will break as soon as it's finally back up and running 👽
Had the same scenario with my Camry. Saved about $500.00 compared to other options, such as described in an earlier posting.I had a custom muffler shop replace the flex pipe section on my '95 Avalon. FAR cheaper than replacing the entire pipe section with OEM Toyota parts.
It's not, if by flexible you're thinking, "like a rubber hose."If that flexpipe pic ii posted is supposed to be flexible
Thank you for the education!It's not, if by flexible you're thinking, "like a rubber hose."
Flexible for this sort of thing is not at all like flexible for non-metallic things. In fact, flexible for this is a lot less flexible than your average empty beer/soda can or food can. It's just meant to be able to flex ever-so-slightly in under heavy stress.
If you want to see how inflexible these are when under normal "I can provide them with my hands" forces, try playing with one in an auto parts store.
They would be far better described as semi-rigid, being very close, but not quite, truly rigid. Essentially, they're supposed to be able to take forces that would make solid exhaust tubing crack (or the hangers pull off somewhere) if that tiny bit of give were not present that they provide.
