1 - 2 of 2 Posts
Hello there im new in these forum my care need new care to regive some life in there so... im here . To solve first problem ... thief audio car system i install a security system i need just some think to finish the installation the tachometer wire i search on the engine control the tach wire (under glove box) and i see 3 possibility 1 black wire between 2 and 6 volt when you accelerate or a green wire between .70 and 5 6 volt when i accelerate. The problem is the remote start cannot learn the tach wire because i d ont know if i have the right wire. Someone can help me. tks
well what i was told is you can use the green wire coming out from the distributor cap(i doubt you have a dist cap cause your prob. 5efe DIS ignition)or from a black wire with a blue stripe inside the engine bay.
heres a link to the tutorial
http://board.tercelonline.com/viewthread.php?tid=12418
theres a pic at the bottom of what your looking for. and u can also use the search engine to come up with more posts on this subject.
1 - 2 of 2 Posts
