1 - 3 of 3 Posts
Ok, I'm sending the car to the garage for tear down.
PM ME WITH WHAT YOU WANT
You all know what's at stake here with regards to new parts on this car. The list has been here for over a month.
If you want something PM ME, don't leave it here, because PMs will be looked at first.
Don't bother low balling me either, it won't work.
An example of a grouping of items would be:
"All 4 control arms with polyurethane bushings & all 4 rear locating arms" (about $1500CDN in parts - would sell for $300USD + shipping)
I'm not going breaking up stuff like that, however, if you would like, i could pull the bushings out of the arms & just ship the bushings and the 4 locating arms.
Check the list & PM me
John
LIST
-Ball joints
-tie rod ends
-power steering rack
-Brake master cylinder
-Clutch master & slave cylinders
-motor/gear box mounts
-clutch, pressure plate & throw out bearing
-water pump, timing belt
-aluminum radiator & rubber coolant hoses
-accelerator cables (2 /cruise control)
-park brake cables (all 3-working)
-front & rear struts & mounts
-Front springs
-calipers, rotors, pads, shoes (less then a year old)
-both front wheel bearings & hubs
-all rear suspension arms
-new polyurethane bushings in control arms
much more, please ask
1 - 3 of 3 Posts
