1 - 13 of 13 Posts
G
That seems too long, but that's what they are telling me.
I'd be more inclined to change it at 500 miles, then again at 3000.
Also the dealer said not to worry about engine break-in, but to "just drive
the hell out of it".
What do you all think?
-jeff
G
Discussion Starter · #2 ·
"Jeff Olsen" <[email protected]> wrote in message
news:BFEA283C.18807%[email protected]
> drive
> -jeff
Keep an eye on the oil level during the first 1000 miles as this is the time
when the engine is supposed to consume a bit of oil. I would change it by
1000 miles. Drive normal.
- Philip
G
Discussion Starter · #3 ·
> drive
> -jeff
Oil change at 3000 okay but from new dont drive over 60MPH and drive it
normally. IE no stomping the throttle or laboring the motor.
I wouldnt drive it hard till the 3000 service has been done. Well, unless
you dont wish to keep the vehicle for more than a few years.
G
Discussion Starter · #4 ·
"Scotty" <[email protected]> wrote in message
news:[email protected]
>> drive
>> -jeff
Rubbish.
A quick, brisk break-in won't hurt the engine ANYWHERE near as much as
running around on oil that is past due for changing.
- Philip
G
Discussion Starter · #5 ·
I changed mine after the first 1000. as far as breakin driving, I was told
by everyone I asked to drive it as I normally would.....not to baby it or
stay under 60
"Philip" <[email protected]> wrote in message
news:UZ9xf.7940$M%[email protected]
> news:43c4ff50$0$11844$afc38c87[email protected]
> >> drive
> >> -jeff
unless
> Rubbish.
> - Philip
G
Discussion Starter · #6 ·
An older ex-Toyota mechanic advised me to:
Keep the first 100 miles under 55, never starying at the same speed (rpm)_
for more than 5 miles.
From 100-500 - don;t exceed 70, same 'holding pattern' advoidance.
Change oil at 1000. It has some 'breakin additives you -want- to work.
after 1000, get it up to speed - a few bursts to 990 will help seat the
remaining parts - AFTER it's fully warmed up - 20 miles of running.
So far, it's seemed to be right. 4 years old, and getting above 22 mpg on
interstate or open road above 70. It's an auto full 6, DC with power toys.
On Wed, 11 Jan 2006 15:40:08 -0500, "Grip" <[email protected]> found these
unused words floating about:
>stay under 60
>> >> drive
>> >> -jeff
>unless
>> Rubbish.
>> - Philip
G
Discussion Starter · #7 ·
I'm not sure that I buy into the "drive the hell out of it" story, but I see
no reason to change the oil.
> drive
> -jeff
G
Discussion Starter · #8 ·
>>> drive
>>> -jeff
>> unless you dont wish to keep the vehicle for more than a few years.
> Rubbish.
There you have it, stomp the pedal and forget about the oil.
My advice stands, drive like you have 72 more payments left, and change the
oil when the schedule calls for it.
G
Discussion Starter · #9 ·
"Jeff Strickland" <[email protected]> wrote in message
>>>> drive
>>>> -jeff
>> Rubbish.
> the oil when the schedule calls for it.
Huh? How did you infer "stomp the pedal, forget about the oil" from my
previous post?
Good grief.
G
Discussion Starter · #10 ·
> -jeff
The guy at the dealership, service writer or salesman, is trained in
sales, not mechanical things.
I favor one or two short-mileage oil changes, then change every 5000
miles. There might be some break in particles or manufacturing
debris in the engine that you want to remove. As far as I know,
only Honda has a special break in oil in their new engines.
All parts of the truck need to break in. Brakes, transmission,
differential, as well as the engine. I like light driving and
varies speeds and loads for the first 500 miles...no towing or heavy
loads in the bed, no street racing. An easy drive on a mountain
road is perfect.
Ken
G
Discussion Starter · #11 ·
"Ken Shelton" <[email protected]> wrote in message
> miles. There might be some break in particles or manufacturing debris in
> the engine that you want to remove. As far as I know, only Honda has a
> differential, as well as the engine. I like light driving and varies
> speeds and loads for the first 500 miles...no towing or heavy loads in the
> bed, no street racing. An easy drive on a mountain road is perfect.
> Ken
Agreed, Ken. One or two short mileage oil / filter changes (1000 and 3000
miles) and then every 5k after. The easy drive on a mountain road IS the
perfect break-in drive.
- Philip
G
Discussion Starter · #12 ·
On Wed, 11 Jan 2006 05:42:13 GMT, Jeff Olsen
>-jeff
I think waiting until the first 3000 miles for the first change is too
much. The initial oil change will contain lots of metal. I plan on
changing mine at 800-1000 miles, then every 3000 after that (the
maintenance guide recommends every 5000 miles). A new engine consumes
more oil, since its pistons, rings, and cylinder walls have not been
conditioned. My dealer recommended to "go easy" the initial 500 miles.
G
Discussion Starter · #13 ·
"Phisherman" <[email protected]> wrote in message
news:p[email protected]
>>drive
>>-jeff
I'm not sure I agree with that position. The factory has to support a
warranty for upwards of 100,000 miles, do you really think they will leave
stuff inside the motor that can do harm and increase the warranty claim
exposure they are facing? I think they would easily spend a few bucks -- and
pass the cost on to the consumer -- to be sure the motor is cleaned out.
Back when this concern came about, they did much of the machine work pretty
much by hand, and the steps needed to clean the metal flakes out were labor
intensive. But, today most of this work is done by robots, and spinning the
motor over to squirt solvent through it doesn't take much effort at all.
I see no problem with changing the oil early, but if there was any real
benefit, the factory would have the dealers call the vehicles in and do it
to avoid the warranty issues that can result if it isn't done.
I have to question any instruction of "drive the hell out of it." That
sounds of pure folly to me, but observing the normal oil change interval
seems reasonable to me.
I plan on
1 - 13 of 13 Posts
