I'm using the FitCamX for the front & would have loved to use FitCamX for the rear as well but I don't think one was available. I'm currently using a Rove 4k in the rear but it's not as inconspicuous as I would like.
Thank you for the great video, @KambientRE ! It helped me with the installation.For those in the market for a 4K dash cam, I recently made a video documenting my experience installing this in my Highlander. I've read reviews from other Platinum owners that the small case cover at the top did not fit with the additional wires from the digital rear view camera. I brang this concern to the seller and am happy to inform others that the company has since created a new cover that allows for extra clearance by snipping off a removable plastic piece along with an update that they have their own dedicated app now.
I will admit that initially finding space to cram the wiring harness was a pain in the *ss that took me 2 hours to figure out but I found a way to tuck them in to make it work. Let my pain be your gain!
Thinkware claims to support only 128gb and recommends using only a Thinkware chip.Their website is ambiguous about this: “128GB(128GB Can Only View Video On The PC, And The Maximum Support For Mobile APP View Video Is 64GB)” - what does this even mean? That half the videos won’t be playable on mobile app when the card fills up? I tried the playback from mobile app and it seemed to be working fine, but the card was almost empty.
Thank you for the inputs. I see the pattern…Thinkware claims to support only 128gb and recommends using only a Thinkware chip.
I'm running Samsung EVO 512s in both of our U1000s and they work just fine after formatting in the camera.
The documentation typically only lists support for products that they have actually tested.
$500 deductible saved, no increase in insurance rates, AAA applied fault to the other party and agreed to process a total loss on my Corolla within 24 hours.Pretty expensive dashcam. Are they worth it?
OP’s video explains how to do it. It helped me get the wires organized wellAny tips for getting all the wires tucked up under there?
I can confirm your words, I also was in the situation when dashcam saved me a lot of money and nerves. I've used only BlackVue in all my cars, but I can see that Thinkware U1000 gives better quality. Now I'm looking for the new dashcam. License plates are much more readable on U1000. May I ask you if you had any problems with the camera? Thanks.$500 deductible saved, no increase in insurance rates, AAA applied fault to the other party and agreed to process a total loss on my Corolla within 24 hours.
Ya... $1000 would be worth it.
The FitcamX is less than $200, not even close to "pretty expensive" as dashcams go.
My Thinkware U1000 was on sale for $400, normally goes for $500
Blackvue, which is another premium product is $400+
Anything under $150 is going to be useful, but won't do well at providing a license plate in the event of a hit and run.
Dashcams are not something you want to cheap out on.
Brilliant!!! I cannot use Blendmount on Platinum trim due to camera mirror and the shape of the stem.Only the front cam on this one.
I used a dremel to drill two holes just above the cam portion of the fitcamx…then screwed in the two long screws to mount it to the plastic housing…then used a cutting disc on the dremel to trim down the screws since there’s not a lot of clearance with the vehicle’s camera…![]()
So far, no issues at all with mine.I can confirm your words, I also was in the situation when dashcam saved me a lot of money and nerves. I've used only BlackVue in all my cars, but I can see that Thinkware U1000 gives better quality. Now I'm looking for the new dashcam. License plates are much more readable on U1000. May I ask you if you had any problems with the camera? Thanks.
The Fitcamx only needs to be connected to an internet connection when you're attempting to view footage or download footage otherwise, 95% of the time, it's just recording on a continuous loop. If you're having issues with consistency, I'd try reformating the SD card from the app. Also try using a high endurance card rated for extreme cold/hot temps as the card can get hot. Another thing the instruction manual mentioned is using a card no higher than 64GB otherwise it can only be viewed from a computer. I've had no issues with mine so far.I've been running this in my 2022 Camry since about Christmas. Install was pretty straight forward. I connected to it via wi-fi and ran a few initial tests. Seemed to work fine. Took a few pics downloaded a clip etc. Then I disconnected the wi-fi so I could use cellular to use a GPS app or access the internet. I reconnected recently to view some clips and see if the cam was functioning correctly. There are a few new clips on there, but about 95% of my drives are not recorded. I don't know what I'm doing wrong? Do I need to leave my phone always connected to it via wifi when I'm driving so that it records? That doesn't seem normal. I really don't want a camera that isn't consistent.
I know Blendmount said it doesn't work with the Platinum but I reused my old 2018 Platinum Blendmount on our new 2022 and It fit under the wires on the mirror stem and works fine.Brilliant!!! I cannot use Blendmount on Platinum trim due to camera mirror and the shape of the stem.
Thanks for the idea.
Thanks for the info. I order 2018 BlendMount.I know Blendmount said it doesn't work with the Platinum but I reused my old 2018 Platinum Blendmount on our new 2022 and It fit under the wires on the mirror stem and works fine.
Some cameras can do that.Do you record if the car is parked?
It means that it is useful in the event of sleep and when approaching the car to try to steal, it is recorded
I have Blackvue and it can record when it parked, camera goes in park mode after 2-3 min of the car parked.Do you record if the car is parked?
