1 - 2 of 2 Posts
06 TACOMA Pre-RUNNER
TOYOTA TACO 06 PRE-RUNNER will use a 3" coilover lift.
Can anybody tell me if this set up will work?
Mojave w Teflon
17x8, 6 on 5.5 Bolt Pattern
BackSpacing = 4.5 in.
Offset = 0 mm.
Hub Centric = No
Center Cap Included = No
Finish = Metallic Gray Teflon
Nitto Terra Grappler LT295/70R17
Terra Grappler, LT295/70R17
Overall Diameter = 33.19 inches
Max Load = 3195
Rim Range = 8.0-9.5 inches
Also I couldent find 285/70R17, will this 295/70R15 work - what's the difference?
Thanks to all.
That's Just Crazy!!
You'll rub on cab mount with a 295. Try searching for
285/70-17 Nitto Terra Grappler AT Tire
You'll still need to trim, but nothing major.
1 - 2 of 2 Posts
