1 - 5 of 5 Posts
I ordered one for a tacoma but they sent me one for the FJ Cruiser. Not knowing this i installed it on my tacoma then removed it shortly after.
$250 plus shipping.
http://www.urdusa.com/product_info....=1260518962&osCsid=ck0dl6l8ihoojl8usrkfv1gcg2
Doug Thorley Headers FJ Y-Pipe is a Y-Pipe for the FJ Cruiser. This Y Pipe eliminates exhaust restriction for greater performance and provides additional ground clearence for off roading. The stock Y pipe crosses right under the transfer case and becomes the lowest part of the truck and is easily caught on off road obsticals. This FJ Y pipe eliminates this problem.
The FJ Y pipe 2-1/4" piping with flanges and O2 Bungs and dual 10 inch resonators on each side of the Y-pipe. This insures maximum sound suppression without impeding exhaust flow. This will help those with Doug Thorley long tube headers to eliminate resonance & high pitched exhaust notes. Paired with a mandrel bent cat-back, this system is perfect for your FJ Cruiser 1GR-FE V6 engine. It fits in the stock hangers with no modifications and fits both 2x4 and 4x4 applications. Installation of this off road Y pipe eliminates the rear catalytic converters and it intended for off road/racing use only and should not be used on public roads on emission controled vehicles.
Doug Thorley's "Pipe Bomb" features:
  • Great Sound
  • Power Increase
  • Mandrel Bent
  • Great Value
  • Doug Thorley Warranty
  • Installs in OEM Location
  • Quick to Install and Remove
1 - 5 of 5 Posts
