1 - 3 of 3 Posts
I have a 15 amp fuse in my power outlet which is 12v switched. I used an add a circuit and it’s running the power for add on DR lights. Now I want to connect the fog lights. Would it be to much to tap the power wire for the DR light to for the ignition wire? Any other suggestions?
Compatible with 2018 Toyota Camry SE XSE LED Daytime Running Light DRL Fog Light Dual Function Turn Signal (Left&Right) https://www.amazon.com/dp/B07KBZDMTG/ref=cm_sw_r_cp_api_i_TG8lEbZVH1GZW
· PJRXJ
Having both DRL and fog light connected to the same circuit is not a wise choice. I have the same foglights/DRL setup. I tapped my DRLs into the headlight connector. I decided against the foglights because the DRLs are really bright. I wish I had known that before I ordered and installed. If your foglights are LEDs there really shouldn't be a problem overloading the circuit but it's wise to have them on separate circuits.
1 - 3 of 3 Posts
