1 - 10 of 10 Posts
I Drink your Milkshake
Wrench Turner
I Like it :D. So if I read your write up correctly the only time the fog lights will come on is when at least the parking lights are on. Also where did you get the add a circuit from and what guage wire are you using (16 or 18) Again nice job and write up.
That looks like the best install/mod yet! Nice work.
I've been "planning" to get the Toyota factory fogs for about a year now... but the $350 price has kept me from buying. What lights did you install? I've looked at the "Blinglights" on eBay, but I'm afraid they'll be junk.
05 Tacoma access cab
Great job !!! :whatwhat: Thanks for sharing another variation of an excellent mod .
Discussion Starter #7
Those are the factory fogs. I have a set of Luminics JDM Yellow Bulbs
Super White Taco
2005 Tacoma
I completed the #2 fog light mod about 2 weeks ago and it was pretty simple. Took about 15 minutes and, so far, I haven't noticed my fog lights turning themselves on while the truck is off. The #2 mod taps into the green wire which only supplies power when key is in the ingition.
jorgem2
2006
GTCOMA said:
I finally did it, but I set up a little different.
Thanks to everybody who posted info on this mod!
Here is a link back to the old sticky thread I added my info to
PICS Included
http://www.toyotanation.com/forum/showthread.php?p=1602785#post1602785
thanks for the tip, I did it today except I wired the bent leg on the relay to the green wire behind the running light bulb and avoided going thru the fire wall. I think that wire is already fused so I shouldnt need an inline fuse should I ?
The lights now work any time the run lights are on and turn off with the ignition key off.
'06 Access 4x4 I4 Manual
06 Taco Access 4x4
I have two foglight relays connected to that same wire with no problems. It is fused (10A I think). Typical auto relay coil currents are around 100 mA (definitely less than 0.5A), so you should be fine.
1 - 10 of 10 Posts
