But do you lose fogs when you turn your headlights on??
^that's what I did. mucho simple!i did the same mod only i just ran a 16-18 gauge wire from the bent post of the fog light relay and tapped/spliced it into the sold green wire on the other end of the fuse box. very simple to do. no issues with lights. brights, low beam, day time running, fog lights stay on at my leisure. no second switches or anything. just use the foglight button.
Did you fuse that wire? Also, do your lights come on 4hrs after you shut off the engine?i did the same mod only i just ran a 16-18 gauge wire from the bent post of the fog light relay and tapped/spliced it into the sold green wire on the other end of the fuse box. very simple to do. no issues with lights. brights, low beam, day time running, fog lights stay on at my leisure. no second switches or anything. just use the foglight button.
I just used your basic wire connectors. just a simple splicer. i shaved a little bit of the green cover off to expose the wire to gaurantee a connection.Did you fuse that wire? Also, do your lights come on 4hrs after you shut off the engine?
There's a sticky at the top of this forum with all the DIY threads in one place. The DTRL with pics is here:which is this the duplicate to? the other threads dont have any pics or theyre broken links
