Sorry i was at school today. I know what you mean about the air bag but i stuck the wire behind the white thing so it would not interfere. Also you COULD the wire towards the middle and down the side middle pillar, but this could be more work. This was teh way Netforcer wired it in his car and this would probably be the easiest way if you DO NOT have a sunroofdo you think the wiring will interfere with the side airbags?? I noticed in your pic right above step # 7, there is a white "thing" in the crack. is that the airbag?
yeah pretty much, you could run it down your side pillar.awesome writeup dude! although im not sure i could use the dome light in your location since i have the gen 5.5 which has the domelight in the middle of the roof and 2 reading lights where the moonroof controls are.. im assuming it would be the same wiring though.
Will do, should have pics by tomorow ? anyways yes i used one cathode per side, the lenth from the cathode it self to the inverter is only about 6 inches so that was a problem but i figured it out, i just placed the inverter behind the cubby hole so the inverter is between both cathodes. Also i used the provided double sided tape at first but no dice, it kept falling so i went to the local hard ware store and bought some Velcro. Sticks alot better.Nice write up. Would you mind taking a picture of the actual lights so we can get an idea of how you mounted them? Also where did you place the inverter and did you only use one cold cathode on each side? Thanks
yeahh.. i would also like to know how.how did you wire the LED light near your AUX hook up? a DIY on that would be amazing.
a very nice write up!
i have a few questions. so for us, who do have moonroofs and like to also add footwells to the passengers in the back? would it be possible to repeat the same steps but using the dome light in the back instead? or something different? and can you give more details for people who would like to do create a switch to turn on/off the lights. thanks.
try using diodes or a relayvery nice write up, think i need to start working on my car more lol
if i wanted to wire up a switch to the footwell lighting as well as run it to the dome light i'd have to run a constant supply in parallel to the dome light power, just add the switch to the constant supply to activate on/off the footwells? Is there an easier way to do this? I'm just thinking if I'm in my car and I want to look for something on the floor, I can flip a switch and the footwells will come on but not the domelight and at the same time they'll activate when the dome is lit.
sorry for the late response but i just got some ricer LED from wal mart for 5 bucks. I have an amp hooked up to my car and i taped into the fuse box as my remote for my amp so it turns on when the key is in ACC or ON. I just tapped into that same fuse i tapped into for my amp so the light is on 24/7 when the key is in. unless i take it out. I think its a nice feature but its kind of odd that the 2 blues dont match up but meh what can you do.how did you wire the LED light near your AUX hook up? a DIY on that would be amazing.
^ hey can i see a pic of your wires and the ones you cut off? it could be different than mine. I am pretty sure i used the BLACK and RED wire. The red wire was connected to the yellow one through a switch though
