My 2002 v6 has made a clattering sound for 1 or 2 seconds on cold startup, since I've had it. The fuel injection computer causes camry engine cold starts to immediately go to about 1800 rpm, i guess to prevent stalling. The engine does not Like this one bit and expresses its displeasure by clatter for several seconds (sounds like connecting rod bearings but could be piston slap). Engine has 176.000 miles.
This clatter has always bothered me. The 1fmze engine is so tough chances are in reality it's doing no harm...BUT Even though it hasn't caused problems yet-the engine is in great shape, normal power, doesn't use oil otherwise normal- I wanted to stop this cold engine clatter!
I tried every additive stp, slick 50 duralube. Marvel. No change in the clatter. Despite what the products say on the bottle not one of them has the necessary "cling" for oil to still be on bearings after overnight.
I decided to even wire in a kill switch to the ecu fuse in the underwood box and even bought the parts. The kill switch was intended to let me crank the engine for 5 seconds to circulate oil before starting. Naturally wiring the switch would not be a pleasant chore. But today I think I found a free solutions. ...
Here's all there is to it. Start the engine allow it to just start then kill the engine immediately before it reaches "clatter speed". Now start the engine normally the clatter is gone.
I think the start- then -stop throws enough oil in the engine to prevent the clatter.
Sent from AutoGuide.com Free App
