1 - 7 of 7 Posts
Hi All
I had messed with my corolla's springs in the past (installed eibach kit) and since then my car pulls to the left. I've had it professionally aligned 4 times to no avail.
Furthermore, I replaced eibach springs with original ones, had it realigned, but still it pulls to the left.
All alignment numbers are within specs.
Did anyone else have this issue? What do I need to do to fix it? This is really, REALLY annoying.
Thanks,
- Russ -
'01 Corolla LE
Country Hick
2001 Nissan Pulsar
have u pulled your steering wheel off recently... or while fiddling with the suspension bumped the steering column and knocked it off centre...
When you say alignment do you mean you went to a modern alignment shop and got a 4 wheel alignment?
If so it should not only give you the wheel angles for the front wheels but also for the rears too.
hemi3TC
rustamabd said:
Hi All
Thanks,
- Russ -
'01 Corolla LE
1 - 7 of 7 Posts
