hi, i've a problem i hope someone can help me with. my 2003 echo has a vibration in the front end at highway speeds of 55-60 mph. it fades away over 65 mph, is not rpm dependant. i have done an alignment, balanced tires, rotated tires, changed left front axle(i thought that was the source of vibration). the vibration goes away if i let off the accellerator and resumes if i accellerate. i looked at my motor mounts but am not sure how much movement is ok. i hate to just throw parts at it. this problem started right after i changed the clutch and pressure plate, but if it was a balance issue it would vibrate at a specific rpm, not speed. if you help, i would really appreciate it. thanks
