About a month ago, I started getting a wobble in the front end of my Corolla. It only happens when I'm towing my motorcycle on my trailer, and it doesn't happen all the time; it comes and goes and it happens at various speeds.
Back in Feb of this year I spun out on some ice and hit the curb with right front rim. I was only going about 5 MPH when it hit. It did hit hard enough to slightly bend the rim, but the car drove fine, so at the time I didn't think it had damaged anything else.
So a couple weeks ago I took the car in to have the problem diagnosed. They said my struts and springs were extremely worn and needed to be replaced and that this could be causing my problem. They also said the half shafts were good. So I had new strut/spring assemblies installed and I still have the problem. I had the tires rebalanced thinking that may be the problem. The problem is still there. This leads me to believe that maybe some slight damage was done to either the half shaft and/or the half shaft bearings that's just now rearing its ugly head, or could it be a bad steering component? How do I go about finding out what's causing this problem?
