hello...
2004 Sienna LE...
my front passenger power window was stuck down. neither the master switch nor the passenger switch could move it. i was able to raise the window up by hardwiring cables from the battery to the motor. it goes up and down without a problem. so, i suspect a bad switch, but which one? with the window up, i reconnect the passenger side switch and the window instantly goes all the way down without me even pressing the button. nor can i stop the window's descent by operating the switch. when i disconnect the passenger switch, bring the window back up to the top, and connect the master switch, nothing happens even if i press buttons.
am i correct in attributing this to a bad switch? if so, which one? thanks
2004 Sienna LE...
