Yeah, when I had wheels with a really low b/s, my lower ball-joints would make a horrible sound when I got in and out of the truck.
Do you have aftermarket wheels?
My Coil overs slightly rub the Sway bar on the passenger side and sqeak like hell sometimes!!!!MOJO06TACO said:It has been about 3 weeks or so since I put the toytech 3" spring lift on, and today I noticed that my front end is squeaking. That seems kinda odd to me. I guess that if it were coming from the rear then I wouldn't be so puzzled. I have never heard anyone say that their front was squeaking.
Probably not a big deal, but it is kind of bugging me. Anyone experienced this after lifting there truck?
I found triflow at OSH, not sure if they have those down in SoCal or not.06lttaco said:my camburg uca's squeak like there is no tommorrow. i have sprayed everything on the uniballs to get them to stop squeaking but no luck. where can i find this triflow stuff that i hear people talking about? anywhere else i should be spraying in order to eliminate squeaks? thanks
This is what I did also, just today, and here's a pic of it!Marc M said:Mine started squeaking after the alignment way back when. Yes, the lower spring cup rubs the anti-sway bar. I removed the U-brackets that hold the bar on and elongated the "round" hole with a file and re installed the other way. The bar now sits about 1/8" further forward than it did so no interference issues at all.
Marc M
Jacobi, did it work for you?Jacobi said:This is what I did also, just today, and here's a pic of it!
After I cut that small piece out I filed down the inside of that hole so that it was a tad bit deeper in order to get the sway bar to sit about 3/16" further forward. Hopefully it works, I'm going for a test ride in a few hours.
Haha, hell no it didn't work. It would for a little while and eventually start making noises again. I tried thread lock and everything, but nothing would work. Well, nothing would work until I tried something new this morning. Let's just say I've got a sway bar sitting in my spare bedroom now...it looks better in there than it did on the truck.movielife said:Jacobi, did it work for you?
Thats the bumper mounts TSBmy stock taco pops and clicks (from the front) when i go over speed bumps. There is a TSB for this i think... it doesnt really bother me that much... so i havent broght it in yet.
There are also defective sway bar bushing. They get hard and crack and make a nice squeaking noise.The "cup" on the bottom of the shock rubs the sway bar. If you put a small spacer on the sway bar mounts, it will rotate the sway bar enough to get it out of the way.
-Barry-
