1 - 2 of 2 Posts
contact info: [email protected] or text for fastest response 661-599-4629
payment: paypal or local cash pick up
selling all my extra stuff to get some money together for a new motor
mine is blown...unless someone has a running 4ag motor they want to trade
items:
1.igniter- a igniter i pulled off my bluetop ae86 works fine $40
2.cluster- gts cluster i pulled out of my 85 ae86 all gauges work no
cracks very clean $50
3.coil- coil i pulled off my gts bluetop perfect working order $25
4.ecu-4age bluetop ecu all connections are in good condition $40
5.microsquirt v3- newest microsquirt out, i was going to use it in my
ae86 but the engine is blown so i need to sell this to get another
motor its brand new about a week old. comes with pretty much
everything needed to put it in for a bluetop. ecu, igniter
module(brand new), injector pigtails, map sensor with plug, tps for
ITBs, resistors for low ohm injectors(like bluetop). also comes with
all of the engine harness you need while running the microsquirt. $350
6.ford edis- all of a ford edis 4 system for a 4age. comes with
everything needed except trigger wheel. i even have spark plug
wires(not pictured). vr sensor has custom bracket already made that
bolts right up to the block and lines up with the trigger wheel if you
put it on front bottom pully. $50
7.egr-full egr system taken off a bluetop ae86 $70
thanks for looking feel free to ask any questions :)
1 - 2 of 2 Posts
