1 - 3 of 3 Posts
FS: NEW Logitech Z-5500 Audio, NEW Canon Printers, Intel Board,etc
BRAND NEW IN BOX Logitech Z-5500 5.1 Digital Speaker System
This is an amazing setup, brand new sealed in box. It simply cannot be matched for the price when it comes to audio, surround sound and PC gaming. Words cannot describe!!! Currently going for $499.99 at Best Buy and 449.99 at FutureShop.
When there’s nowhere to go but up, choose the Z-5500. Experience music, TV, movies and games through this THX-certified, 505-watt 5.1 digital surround sound speaker system with digital equalization
Onboard 5.1 Digital Decoding: Hear every detail of your favorite Dolby® digital and DTS soundtracks.
THX Certified Sound: Settle for nothing less than the THX seal of approval for master quality.
505 Watts: Turn any room of your house into a powerful theater.
10" Long-throw Subwoofer and Tuned Bass Port: Get 188 watts of powerful, distortion-free bass.
Aluminum Phase Plug Satellites: Combine the clarity of a tweeter with the richness and fullness of a separate mid-range.
Specifications:
  • Satellites: 3” polished aluminum phase plug drivers
  • Subwoofer: 10” high-excursion ported driver with 6th order bass reflex enclosure
  • Surround sound effects
  • Hardware decoding:
  • Dolby® Digital, DTS®, and DTS®, 96/24 soundtracks
  • Dolby Pro Logic II (Movie and Music modes)
  • 6 Channel Direct
  • Stereo x2
  • Stereo
  • Digital optical for DVD or CD players, PlayStation®2, Xbox®**
  • Digital coaxial for DVD or CD players or PC sound cards (requires coaxial cable, sold separately)
  • 6 channel direct (3 stereo-mini connectors) for 2, 4, or 6 channel PC sound cards OR
  • 6 channel direct (3 stereo-mini connectors) for 3 stereo analog mini audio sources, like CD and DVD players, Playstation 2, Xbox, or 2 channel PC sound cards (somedevices may require stereo mini to dual RCA adapter, sold separately)
  • Analog stereo-mini (on side panel of control center) for portable CD, MP3,or MiniDisc® players
  • Total FTC power: 505 watts RMS
  • Sub-woofer: 188 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD)
  • Satellites:
  • Left/Right: 62 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)
  • Center: 69 watts RMS (into 8 ohms, @ 1kHz, @ 10% THD)
  • Rear Left & Right: 62 watts RMS x 2 (into 8 ohms, @ 1kHz, @ 10% THD)
  • PC/Mac Compatibility
  • CD Compatibility
  • MP3 Compatibility
  • DVD Compatibility
  • PlayStation® Compatibility
  • Xbox® Compatibility
Asking $250.00
BRAND NEW IN BOX Canon PIXMA MP210 Photo All-In-One Printer
  • High Resolution: Precision ink nozzles create high resolution photos—up to 4800 x 1200 color dpi.1
  • Fine detail: Microscopic 2-picoliter sized color ink droplets produce finely detailed and sharp photos.
  • Impressive Scans: Produce high-quality scans up to 600 dpi with vibrant 48-bit color depth.
  • Long-lasting Photos: Using select genuine Canon inks and photo papers, you can create beautiful photos that last up to 100 years.2
  • Copy/scan thick originals: You can even copy or scan thick items that do not lie flat on the platen.
  • Click-Connect-Print: Just capture an image with a PictBridge-ready digital camera/DV camcorder, then connect and print!
  • Smart copying: Dual Color Gamut Processing Technology automatically optimizes quality based on the type of originals you are copying.
  • Fast Photos: In approximately 46 seconds, you can produce a photo-lab quality 4" x 6" print.2
  • Easy Reading: The display's numbers consist of up to 7 large LED segments, for easier reading and operation.
Asking $80.00
Canon PIXMA iP6220D Photo Printer - BRAND NEW, SEALED IN BOX
Stylish Personal Minilab with 2.5" Color LCD Viewer for Easy Photo Direct Printing.
  • Large 2.5" color LCD viewer for easier viewing with built-in red eye reduction and image enhancement
  • FINE cartridges for impressive photo quality
  • High performance photo printing with 6 color ink tank system featuring ChromaLife100 inks for long lasting, beautiful photos
  • Direct photo printing from select memory cards and PictBridge ready devices
  • Maximum 4800 x1200 dpi with micro-scopic droplets as small as 2 picoliters
  • Borderless 4"x 6" photo in approx. 1 minute
  • Create stunning 4"x 6", 5"x 7" and 8.5"x11" edge-to-edge, borderless photos
Asking $65.00
BRAND NEW RETAIL BOX - Intel DG33TL mATX LGA775 G33 DDR2 PCI-E16 2PCI-E1 PCI SATA2 Sound Video RAID 1394 Motherboard
The Intel® Desktop Board DG33TL Media Series in the uATX form factor delivers improved performance and capabilities for multimedia creation and enjoyment. With support for Intel® quad-core processors and Intel® Viiv™ processor technology?, this desktop board merges the energy-efficient power of the Intel® Core™2 Quad processor with enhanced expandability, graphics, and consumer electronics integration.
Specifications:
  • Form Factor - Micro ATX
  • Supports many different processors including Intel® Core™2 Quad processor & Intel® Core™2 Duo processor in LGA775 form factor
  • All Supported processors here - http://www.intel.com/support/motherboards/desktop/dg33tl/sb/CS-026653.htm
  • Memory - Support for DDR2 800, or DDR2 667 MHz DIMMsFour 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR2 800, or DDR2 667 MHz DIMMs
  • Support for up to 8 GB of system memory
  • Chipset - Intel® G33 Express Chipset
  • Audio - 8-channel (7.1) audio subsystem with five analog audio outputs and one optical S/PDIF digital audio output using the Sigmatel STAC9271D* audio codec
  • Video - Intel® Graphics Media Accelerator 3100 onboard graphics subsystem with Intel® Clear Video Technology
  • LAN - Gigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82566DC Gigabit Ethernet Controller
  • Twelve USB 2.0 ports (6 external ports, 3 internal headers)
  • Six Serial ATA 3.0 Gb/s ports, including 1 eSATA port with RAID support
  • Two IEEE-1394a ports (1 external port, 1 internal header)
  • Consumer IR receiver and emitter (via internal headers)
  • One Parallel ATA IDE interface with UDMA 33, ATA-66/100/133 support (2 devices supported)
  • One serial port via header
  • One PCI Conventional* bus add-in card connector
  • Two PCI Express* x1 bus add-in card connectors
  • One PCI Express* x16 bus add-in card connector
  • Microsoft Vista* Premium Ready
  • More specs here - http://www.intel.com/products/motherboard/DG33TL/index.htm
Asking $115.00
BRAND NEW Microsoft Windows Vista Home Premium Edition 32BIT DVD
Windows Vista introduces a breakthrough user experience and is designed to help you feel confident in your ability to view, find, and organize information and to control your computing experience.
  • Authentic Key Code, never been used
  • In Sealed package
Asking $115.00
If interested, please e-mail me at [email protected] or PM me.
I am located in the west end of the GTA (Brampton/Mississauga) for local meeting.
Thanks
1 - 3 of 3 Posts
