1 - 20 of 20 Posts
抵抗は無駄で&#
FS: OEM used ECM, VSV for EGR, ECT for EFI and calif oxygen sensors 5S-FE
Recently I have been pursuing high positive fuel trims at warm idle on my car (2000 Camry Solara SE 2.2L 5S-FE) and decided to replace a few sensors and the VSV. it all changed literally nothing per my problem (reason turned out to be purely electrical) and those below sensors are perfectly fine and might serve you for a very long time (e.g. VSV for EGR and ECT for EFI rarely go bad).
Sensors are in same condition as i pulled them out, they were never cleaned with anything (didn't even wiped them clean) as i was afraid to damage something. They look exactly same as after removing them from car.
To make this clear: I NEVER HAD ANY TROUBLE CODES RELATED TO ANY PARTS I SELL HERE. I was replacing them with brand new parts while tracking down my fuel trims problem (still happening with all below new).
Pictures are REAL and were NOT touched or photoshopped. If you need more or better pics at different angles, let me know.
Bottom line is that all those sensors (and VSV) work perfectly fine and are for sale.
Take them if you want. Selling as is. PM me if interested.
I.
Engine Coolant Temperature:
Description: ECT for EFI
OEM part number: 89422-35010
Pictures:
*REMOVED*
Age: 72,551 miles
Notes:
New OEM/Denso sensor I installed in its place didn't change ANYTHING, so this sensor must have been working fine, showing same temps via obd2 as good as brand new one.
Price:
SOLD
Warranty: As is.
OEM Compatibility with following Toyota years and models:
Coolant temp sensor, 4-runner 1992 - 1994
Coolant temp sensor, 4-runner 1995 - 2002
Coolant temp sensor, avalon 1995 - 2006
Coolant temp sensor, camry, 6 cylinder 1994
Coolant temp sensor, camry, 2.2l 1999 - 2001
Coolant temp sensor, camry, 3.0l 1995 - 2001
Coolant temp sensor, camry, 3.0l, w/o solara, japan built, marked 9422-35010 2002 - 2003
Coolant temp sensor, camry, 3.0l, w/o solara, usa built 2002 - 2003
Coolant temp sensor, camry, 3.0l, w/solara 2002 - 2003
Coolant temp sensor, camry, 3.0l, 3.3l, usa built, usa part, p/n label 8942235010 2004 - 2006
Coolant temp sensor, camry, 3.0l, 3.3l, usa built, japan part, p/n label 8942235010 2004 - 2006
Coolant temp sensor, solara, 3.3l, p/n label 8942235010 2004 - 2008
Coolant temp sensor, celica, st, gt 1992 - 1993
Coolant temp sensor, celica, all 1994
Coolant temp sensor, celica 1995 - 2005
Coolant temp sensor, corolla 1993 - 1994
Coolant temp sensor, corolla 1995 - 1997
Coolant temp sensor, corolla 2003 - 2008
Coolant temp sensor, highlander 2001 - 2003
Temp sending unit, highlander 2001 - 2003
Coolant temp sensor, highlander, 3.3l 2004 - 2007
Temp sending unit, highlander, 3.3l 2004 - 2007
Coolant temp sensor, highlander hybrid, marked 8942235010 2008 - 2009
Coolant temp sensor, land cruiser 1993 - 1994
Coolant temp sensor, land cruiser 1995 - 1997
Coolant temp sensor, matrix 2003 - 2008
Temp sending unit, matrix 2003 - 2008
Coolant temp sensor, mr2 2000 - 2005
Temp sending unit, mr2 2000 - 2005
Coolant temp sensor, pick-up 1992 - 1994
Coolant temp sensor, pick-up 1995
Coolant temp sensor, prius 2001 - 2003
Coolant temp sensor, rav4 1996 - 2003
Coolant temp sensor, sienna 1998 - 2003
Coolant temp sensor, sienna 2004 - 2006
Coolant temp sensor, supra, w/turbo 1993 - 1994
Coolant temp sensor, supra, w/turbo 1995 - 1998
Coolant temp sensor, t100 1993 - 1994
Coolant temp sensor, t100 1995 - 1998
Coolant temp sensor, tacoma 1995 - 2004
Coolant temp sensor, tundra, 4.7l 2002 - 2004
Coolant temp sensor, tundra, 3.4l 2000 - 2004
Coolant temp sensor, 2006 - 2007
*data taken from online toyota dealer catalog.
II.
Exhaust Gas Recirculation:
Description: VSV for EGR (on the back of engine block, below intake manifold)
OEM part number: 25860-74050
Pictures:
*REMOVED*
Age: 73,700 miles
Notes:
New OEM/Denso VSV I installed in its place didn't change ANYTHING per my problems with EGR, so it must have been working fine.
As you can see the VSV itself is perfectly fine and very clean (i was surprised), only the metal bracket is covered with a little rust, but this is nothing per functionality. Both ports and filter look clean like new.
I have tested this VSV per FSM (gen4 SFI, page 43) and it passed all tests with flying colors every time. It's same good as brand new one.
Price:
SOLD
Warranty: As is.
III.
Oxygen sensors:
a)
Description: upstream Air/Fuel ratio sensor (california specs only)
OEM part number: 89467-33020
Interchanges:
Denso 234-9010
NGK 24657
Pictures:
*REMOVED*
Age: 71,700 miles
Notes:
It still includes original electrical connector intact.
New NTK sensor I installed in its place didn't change ANYTHING, so this sensor must have been working fine. It might be only a little slower than brand new sensor, but for this price you can get it and either live with it for another 70k miles or re-use the electrical connector for splicing, replacement, etc.
Price:
SOLD
Warranty: As is.
b)
Description: downstream narrow band o2 sensor (for federal and california specs same)
OEM part number: 89465-06040
Interchanges:
Denso 234-4137
NGK 24566
Pictures:
*REMOVED*
Age: 71,400 miles
Notes:
As you can see i have stripped it a little bit (shouldn't be any problem during installation though). This one was a bitch to remove due to tight working space under car. eventually i got it off using my 1/2'' click-stop torque wrench (breaker bar was too big to fit in).
It still includes original electrical connector intact as well as grommet and wire clip that fits under car.
Price:
SOLD
Warranty: As is.
IV.
ECM / ECU Engine Control Module/Unit:
Description
: Original factory (built APR 2000) ECM from '00 Solara SE 2.2L (calif specs, no immobilizer, automatic).
OEM part number: 89666-06041 (interchangeable with 89666-06040, 89666-06120, 89666-06121, etc.)
Pictures:
*REMOVED*
Age: 74,600 miles
Notes:
It is said that same exact components (including the ECM, engine, transmission and everything under hood) was also used for respective 2000-2001 Camry gen4.5 models (also calif specs, no immobilizer, automatic).
There is nothing wrong with this computer. The sole reason why i replaced it, was because i cannot find the source of my fuel trims problems and decided to replace it with the one with latest software revision (from junk yard). It works perfectly fine and is VERY clean (unlike those junk yard pulls), perfect condition.
Newer software revision ECM I got from junk yard (89666-06121) didn't change ANYTHING, so this old computer must have been working fine, no errors, no problem. I replaced it only because i wanted a newer software revision on the computer and was hoping it would solve my trouble (it didn't).
Price:
SOLD
Warranty: As is.
Above items are not intended for tune up. I am trying to sell them to people who get annoying error codes and are looking for a cheap & quick repair or want them to re-use e.g. electrical connectors.
Drop me a PM if interested in any of those items or need more info. Free USPS Shipping within continental US.
Thanks for looking!
ANY comments appreciated :)
抵抗は無駄で&#
Discussion Starter #2
i can accept some best offers too, not only my own fixed prices.
What Toyota?
I was about to FLIP OUT because I JUST bought a B1 S1 O2 sensor. Luckily, the federal spec 1MZ one doesn't match up.
抵抗は無駄で&#
Discussion Starter #5 (Edited)
hehe, nice to hear some comments here :D
just did the price CUT!!! :D
so if anybody interested then take them, all works fine.
soon will update with a working ECM for 5S-FE camry gen4.5 2000-2001 (no immobilizer, CA emissions, automatic transaxle) or equivalent solara (2000-2001). one of early revisions (built APRIL 2000, part number 89666-06041).
Man I wish I needed these parts. Or knew you back when I bought a brand new VSV from the dealership for ~$80.
Oh well.
To anyone reading this, these prices are a steal. Especially factoring in the free shipping?
I might just buy these just because they're so cheap haha.
抵抗は無駄で&#
Discussion Starter #7 (Edited)
hehehe, glad to hear it the prices are good! that's what i wanted to achieve considering the age/mileage/condition of items I tried to reduce price proportionally :)
and yeah i decided to put free shipping as calculating those stamp prices (per weight and i don't have a scale precise enough for small packages) is a PITA. i hate that on ebay when i sell something, so i either make it free (less hassle, more potential buyers) or set it fixed higher based on furthest location i ship to (less potential buyers).
i have no use for those items at all. they would be picking up dust only if i keep them. i'd rather sell them cheap to anyone in need.
if there will be no buyers until July then i will put them on sale with ebay i think. however prices will be different, because TN members have always a right to get them from here cheaper.
i bought my new VSV for $58 from toyotapartsoutlet.com with free shipping, but then i couldn't find a way to remove the old one, got annoyed after 2 hours of poking around from the top and bottom, in the end went to local shop and paid mechanics $90 for labor (1.5hrs book time) on VSV for EGR replacement :facepalm:
though i was watching them all the time and talking with them (they are good guys), so now i know exactly how to replace it myself - through the f**kin wheel well on passenger side! :facepalm:
抵抗は無駄で&#
Discussion Starter #8
bump, anybody anything ?
will be selling some of those on ebay soon.
抵抗は無駄で&#
Discussion Starter #10
last call before i put those thingies on ebay ... though i still can't find time to do that.
抵抗は無駄で&#
Discussion Starter #11
VSV for EGR got sold.
the rest is still up for sales if anybody interested.
抵抗は無駄で&#
Discussion Starter #13
updated the ECT for EFI (coolant temp sensor) with full compatibility listing for various toyota years/models as per online toyota catalog.
price cut on 5s-fe ECU (ECM), now asking only $80 shipped free.
抵抗は無駄で&#
Discussion Starter #16
thanks :D
now ... if i could only find a used body harness (fuse boxes) for my '02 solara v6 hehe ...
抵抗は無駄で&#
Discussion Starter #18
sooo, maybe somebody want this?
it fits almost all Toyotas :)
抵抗は無駄で&#
Discussion Starter #19
AFR sensor got sold (ebay).
the only thing left in this FS thread is the Engine Coolant Temperature sensor for Toyotas (variety of models and years).
抵抗は無駄で&#
Discussion Starter #20
last item from this listing (ECT for EFI) got sold on ebay. no more things to sell here :)
1 - 20 of 20 Posts
About this Discussion
3 Participants
fenixus
Toyota Nation Forum
Full Forum Listing
