Do you all use fuel additives? If so, what do you recommend? Thanks.
Ron
99 Corolla CE 111K miles
Ron
Isophorone said:Do you all use fuel additives? If so, what do you recommend? Thanks.
Ron
my manual is chock full of typos and mistakes :lol: says i need 91 octane...91 RON which is like 87 PON. then the pictures and descriptions for the 1.6 and 1.8l engine bays are swapped!schn0354 said:As long as you go to reputable gas stations (almost all are), all grades will have enough additives already in the gasoline. You will want to check your manual for the correct octane level. Best thing you can do is make sure the engine is tuned up. If not, an incorrect air/fuel mixture can leave harmful deposits in the intake system and combustion chamber.
bring on the pr0n!bonnie* said:Otherwise it sound to me like PON + RON = P.......RONt:
rder:
you asked for it!REN69 said:bring on the pr0n!![]()
- 1.8 litre 7a-fe block oversized, decked and machined
- 7a-fe crank with new oem bearings
- 7a-fe rods with new oem bearings
- 4a-gze US Spec 8:1 pistons 81.5mm oversized new OEM
- Estimated 8.8:1 compression
- New oem piston rings
- New oem head gasket
- 4a-ge big-port head, ported, decked et machined
- 3s-gte intake and exhaust valves
- HKS 264 intake and 256 exhaust cams 8.35mm lift
- homemade adjustable cam gears
- New oem water pump
- Shimmed new oem oil pump
- TRD thermostat
- 4a-ge big port NA intake and throttle body
- Complete oem gasket and seal kit
- Toyota Previa Van 2tz-fze SC14 1435cc supercharger with 125mm SC12 pulley
- Blitz Dual Drive Blow-off valve
- 7m-gte front mount Intercooler
- 7m-gte 440cc injectors
- Venom High Flow 3s-gte fuel pump
- AE101 gze turbo pressure sensor OEM
- AE101 gze ECU
- AE101 Crank sensor
- AE101 gze coils packs
- 7m-gte igniter
- E-manage piggyback unit with injector harness and Greddy map sensor 3 Bar
- Custom coolant piping
- Custom intercooler piping
- Custom wiring
- Custom engine mounts and accesory brackets
- New oem belts
- HKS Crank pulley with dampener
- K&N air filter
- Twincore OEM Toyota radiator made to fit
- Trimline Flexalite electric fan with home made relay
- ACT clutch kit (pressure plate, clutch) good for 300 lbs of torque
- 2.5" exhaust piping
- Hi-Flow Dynomax catalyst
- Hi Flow Dynomax 3 pass exhaust
