Doesn’t matter.Seems to me the orientation of bolt matters because
when you use the bolt with both oem washers the hole lines up,
Doesn't matter.When you use the bolt with both aftermarket washers the hole lines up
Doesn’t matter.But when you use the bolt with one oem and one aftermarket washer the hole doesn't line up
Doesn’t matter.Or maybe it's the new wix filter causing the two mismatched washers to not line up the holes
