PITA is right!
Just to vent and share a bit- did wife's 97 Avvy fuel filter today. Did have to pull the airbox, wheel and the little 2 bolt skirt, all for much easier access. Not too bad so far- about 15 minutes total. Everyone says the bottom fitting is the bitch, but mine came off pretty easily- even used a 9/16" open end 'cause I couldn't find the 14 mm. The top fitting was the pain- twisted the bracket before it finally popped loose, but it bent back easy enough. Get it all back together, then can't get the banjo to quit leaking. Torqued it to spec on initial assembly, but got the wrenches and went as far as I could- no luck. New copper washers w/ filter from the Zone, but seemed too narrow compared to original aluminum ones. (BTW- AZ only has one no name brand filter- go to Advance for Fram next time) Tried putting old washers back on- better, but still leaking. Back to AZ- explained prob- guy found pack of copper brake fitting washers in help aisle. Had a couple in it that almost matched, just had to file the ID a tiny bit, leaving it ever so slightly undersized so the bolt had to force its way through. (They were also a bit wider as well on the OD, which I was glad of too.) Torqued it down again, still slight leak! Got the wrenches out again and cranked it as tight as I could, and finally got it to seal. Maybe the aluminum washers are the key- who knows. Total time- 5 hours including 45 min trip back to AZ. Grrrr.
