Fuel Injection
1215 Views 1 Reply 2 Participants Last post by  toyomoho
How do places like Jiffy Lube clean your fuel-injection system if you tell them too? My car's fuel injection system is probably dirty because my gas pedal doesn't have the smooth motion like our other cars have. I've put STP fuel injector cleaner down the gas tank the past 2 fillups and it's helped maybe a little bit when it was in the tank but goes back when it's all gone. Anyone know a more thorough way to clean it?
1 - 2 of 2 Posts
The throttle valve is controlled by the gas pedal. The injectors respond to throttle position and intake air flow. Need to clean inside the throttle body around the valve area, many folks spray on Seafoam.
Also check the throttle cable and gas pedal function.
1 - 2 of 2 Posts
