Techie question here....
Several months back we replaced the injectors on a 3SFE engine in a 1987 Camry. The replacement injectors came from a 1988 3SFE and had a slightly diffrent plug along with the Injectors themselves being a different color. The original 1987 injectors were grey body and the ones from the 88' were blue body. At the time we surmised the difference was most likely in flow rates and proceeded to swap out the injectors along with the plugs from the 88' harness.
The car has run well since the swap, however someone pointed out the resistance of the new injectors may cause undue strain on the 87' ECU and cause it to burn out prematurely. So I did a little homework and here is what I found.
Injector specs
So my question is this: 1 Since there is a resitance difference should I change out the ECU in the car? 2. If I leave this the way it is, will it hurt anything? As it seems to me the ECU's I've seen from both years should actually be the same.
Injector specs
