I have an 87 Supra, non turbo. I confirmed last night that the fuel line going from the (dampener/some assembly above the rear right axle - don't have Chilton's handy right here to ID it?) to the fuel tank is leaking, a nice fountain of fuel. It's rusted pretty badly. Ugh! I hate corroded lines, just did a brake line job on a Sentra that was hellish.
Chilton's is not too helpful in this area, but I think I have a plan and am hoping someone here has done this and can answer my questions and let me know if my plan is a good one.
First question - the line that is leaking comes from the (dampener?) to the tank, there is a hard line from tank to a nut or union, then a small piece of hard line after that nut/union that goes into a rubber hose. There is no clip holding the line to the rubber hose, so I wondered if this was a hose or just an insulated part of the hard line - it felt hard. I'm not sure what it is. Can I just replace the line up to the rubber hose or is that a complete hard line from the (dampener?) to the tank?
Next question - my experience with corroded brake lines is that if you're doing one, you should do them all. Is that a good rule of thumb with the Supra fuel lines?
Next question - I saw a message for a Camry fuel line replacement that preformed lines are available? Is that true for the Supra as well? Stealership the only place or alternative (cheaper) options?
The plan:
Per Chiltons:
1. Relieve pressure in the lines (Do I need to do this since the line is broke or is this just to remove fuel from the system?)
2. Drain the tank.
3. (My thought at this point was to unclip the other two lines that look OK and have clips attaching them to rubber hoses, then undo the line that is broke from the rubber hose, if that's possible)
4. Drop the tank, per Chiltons
5. Replace one/all the lines, just from the tank to the rubber hoses.
6. Install tank. Refuel. Check for leaks. Per Chiltons.
Any got'chas that you've run into when doing this job on your own?
Thanks!
Regards,
Michael
The plan:
Per Chiltons:
2. Drain the tank.
Thanks!
Regards,
Michael
