i have a 2000 Tacoma and the fuel pump wont run when you first turn the key on but when you crank it over it will build up fuel pressure i have changed the pump and checked all the fuses and relays but i cant seem to figure out the problem if the pump does run to build up fuel when you turn the key on it makes the truck really hard to start because it doesn't have enough fuel in the fuel rail for it to run right once the pump catches up the truck runs fine but if you let it set long enough for the fuel pressure to drop again it is hard to start does anyone know what would cause the fuel pump not run when you first turn the key on any help would be appreciated im about to lose my mind :headbang:
