1 - 5 of 5 Posts
Howdy just Swapped my BIG GMC 4x4 Gas drinker peice of crap for a nice 1992 4x4 yota
its got some rust ect.. But anyways what im wondering is when can i find the fuel pump relay ? pics would be best if possible ..
I suspect the fuel pump is shot i pulled the main gas line cranked the key and no pressure no gas pissin out ... Got spark no fuel ....
thanks Coyota
Soylent Green sales
The Circuit Opening Relay is above the pass side kick panel.
But IIRC you have to jump 2 of the pins in the test conector to check the fuel pump.
hey right on thanks i will look there thanks
when you say IIRC? Do you mean the diagonistic box under my hood close to the black fuse box? If so which pins exactly..
thanks
Coyota
Heres the picture of the diagnostic box
Now which pins do i connect?
feel free to copy this image and use paint to show which pins i need to connect to test my fuel pump...
1 - 5 of 5 Posts
About this Discussion
3 Participants
Jayota
Toyota Nation Forum
Full Forum Listing
