1 - 7 of 7 Posts
Hey Guys,
I just bought a 2007 Rav4. Its 4 Cylinder and the limited edition. Had a question about using Fuel Saver Chip on this car since I feel it sometimes lacks power. Had someone used a a fuel saver chip in their rav 4s and would someone recommend it?
Thanks Guys,
· This Space For Rent
Don't do it, it's a waste of money, you'll be using more gas. It's basically a 5 cent resistor that fools the computer telling it the air coming in is actually cooler than it really is thus using more fuel.
How much power are you looking for? Nickel and diming it won't get you anything, but a lighter wallet. If you want a significant increase in HP you'd have to get a supercharger or a turbo.
edit: remember, you have a 4banger, you can only get so much out of it. Maybe you should have gotten a V6?
Discussion Starter · #5 ·
You are right. I should have gotten a V6. At the time of test drving the Rav4 I did not see much difference in power between the 4 and the 6. It is when i am going up a hill I notice the difference. Should have thought of that before I bought the car.
2006 RAV4
Wow, you didn't see a difference between 166 HP and 269 HP??
Sorry to say, but I don't think you test drove the V6.
I have the I4 and think it has plenty of power for my needs, but I drive on relatively flat land, with (max) 2 people in the car, and I don't tow anything. If I did any of these things I would have bought the V6.
Coming from a big truck with a v8 I can definitely tell the difference. But it's not horsepower as advertising will have everyone believe. The torque is what you feel pulling you up a hill. Also the RPM where the power is most powerful is key. Actually the 4-cyl makes alot of power lower in the rpm range than the 6-cyl so it's power is more usable.
I test drove a 4-cyl and a 6-cyl Rav4 and felt very little difference in "usable" power. Be realistic, test drive a car how you will drive it. If you plan to be a speed demon test drive that way, if you plan to be a normal part of society do that on your test drive. The power difference between the 2 engines is higher in the rpm range than most people drive most of the time, so most people would never "feel" any difference.
My little 4 cylinder Rav4 has more than enough oomph for driving to and from work and having more than enough fun.
1 - 7 of 7 Posts
