Hey there,
Just finished a full engine rebuild on a 94 Previa sc AWD (2tz-fe) predicated by a cracked head. My first full engine rebuild, though I have done tons of work on 22r engines in the past. After putting 500 miles on it around town, drove it from Colorado to Chicago. It ran fine over-all but I have a few questions if anybody has the time.
1. It had somewhat low power on mountain pass climbs- couldn't stay at 60-65mph. Is that normal for the little 4 banger with a super-charger? I know my trucks with 22rs couldn't stay up to speed either. I did not own the van pre-rebuild so I don't know its performance.
2. Its running rough (and a little high) at idle and sometimes has a bit of a stall when accelerating cold. Que paso?
3. Just recently, the oil light (not oil level light) blinks when accelerating from a stop or turning hard. Plenty of oil and no light even during hard acceleration at speed. Oil viscocity too low? I may have put in 5-30 , I can't remember. The book recommends 10-30 in summer.
4. How do you know if the super-charger is working or needs maintenance?
5. Check engine light was on for at least a year before the head cracked. It was not on for the first 5 minutes of its new life, but I ran it out of gas (freaked out about that for 45 minutes before realizing it- ha ha) and then it came on on the next start. Maybe unrelated. Probably ought to have that looked at, eh? I don't have any experience with checking or reading diagnostic codes (or the gear), should I have a mechanic run it and get a final check-up on everything?
5. Finally, all the engine (except pistons, crankshaft, block) and timing components are new. Anything else I ought to replace, maintain along with the rebuilt engine?
Thanks- I will post pictures of the rebuild soon and explain some mistakes/solutions that I ran into, because if I can do it, anybody can and it may inspire some newbies to dive in.
