1 - 7 of 7 Posts
is anyone out there have found a full mask that will fit a limited 07, similar to this./ / / / /http://www.toyota-parts.com/PD-PT218-07050.aspx?MakeID=1/ / / /, will this fit on 07?
any opinion.
any opinion.
Please, no, don't do it.
Front bras or masks do more damage than they prevent. Invariably, dirt, grit, dust or whatever gets in between the paint surface and the underside of the bra. Then, with any movement of the bra as from wind or vibration, scratching always occurs.
Bras or masks also trap moisture and force it into the paint which, over time, eventually leads to clouding.
They're just bad news.
If you're really looking for rock chip protection, try the 3M clear sheeting material that is custom cut to fit the contours of the car. It is virtually undetectable when installed properly and easily removed. You see it alot on high-end cars like BMW's and MB's in the valley here.
08 Toyota Avalon XLS
NNNOOO dont do the mask thing. Even the Clear 3m ones are bad for your car because once you take it off you will see a difference in the color dept of your car. Also if you get moisture in there you will will start seing mold start forming under that clear plastic. Im talking from experience. Just leave it as is and when necessary paint your bumper over again. Its not to expensive to repaint.
Discussion Starter · #6 ·
Thanks for the heads up, i actually already ordered it, but luckily didnt put any $down for it.
Discussion Starter · #7 ·
I agree. And those clear plastic protection sheets are available on ebay. Do a search for Avalon in the automotive parts area.
Does anyone have this "lear plastic protection" on their avy?
Do this cost about $ 300 or more , is it worth it?
1 - 7 of 7 Posts
