Fuse problem on '93 Celica..Help !!
1293 Views 5 Replies 2 Participants Last post by  91celicagt-s
Greetings, I own a 1993 Toyota Celica. I have an issue with the A/C blowing a Guage Fuse..I turn on the A/C and it blows the Fuel and Temp. Guage 15 AMP Fuse..can anyone tell me if they have experienced this or a quick diagnosis for the problem? Sure appreciate all replies..Thanks again, gman34667
1 - 6 of 6 Posts
· Can you kill a toyota?
94 Toyota 4x4
When you turn on the a/c does the a/c work? The Compressor clutch engage when the a/c is turned on? What about the little light on the a/c button? Does it come on when you push it and what does it do whenever the gauge fuse blows? Stay lite or go out also? What I am getting at is possibly the light behind the a/c button is shorted out, causing the gauge fuse to blow due to the excess current flowing. Just a guess. I have a wiring diagram on my other computer. I will look at it when I can access it.
Discussion Starter · #5 ·
Will look into that as soon as I return home
Thanks for the process to look into- I am working the Superbowl in Miami-when I return home next week I will try those things.. I will get back to you here..and if you could check out that diagram that would be fantastic..thanks a million..gman34667
94 Toyota 4x4
I checked the diagram out several times and couldn't find anything that would cause that problem in the a/c clutch circuit that would interfere with your gauges. When you get home and check it out just keep us posted. I am sure someone here can help you figure it out.
1 - 6 of 6 Posts
