1 - 16 of 16 Posts
back again? yeah, i am.
1992 Toyota Camry
got everything out of the gauges...but i cant figure out how to put the white face on the OEM one....do i have to take off the needle????help???
1992 Toyota Camry
Discussion Starter · #7 ·
thats what i thought...i pullled the needle hard i hop[e i didnt damage it...but it didnt come off...i tried the needle through the hole thing but the trip needle got in the way
Someone posted a tutorial on this (very well illustrated) and they cut a slit in the gauge to help it pop on the odometer stick after you slide the gauge over the speedo needle.
Do NOT remove needles!
- Paul
Traitor
i just got mine in the mail like 10 minutes ago and i was looing at the wiring and there is a red and black wire...which on is for power and which is for ground...and where to i ground it? or are they both for power
edit: is double sided tape the best way to stick the on there?
You always ground the negative wire (generally black). The hot wire (positive) is generally either red, or has a stripe down the side of it. This doesnt apply for factory wiring, just aftermarket accessories. So in this case you ground the black and connect the red to a power source.
Grenaded piston
stock93cam said:
so which one is grounded + or - and ppl who have done this before where did you ground it?
- (ground)
+ (positive, hot, constant)
Theres a bolt or nut in the opening the guage cluster fits into. Anyways remove the bolt or nut, tie the black wire from the gauges to it, and tighten the bolt / nut back down.
The red wire (positive) hooks up to the parking light wire. Its a green wire on one of the plugs that goes into the guage cluster.
Traitor
thanks you 88 LE thats the info i was looking for...now i can install my gauges...when i get the time :lol: darn
edit: i have this some stuff left over from when my mom was mounting some pictures
is it sufficient for the gauges...it says... "long lasting adhesive"
1 - 16 of 16 Posts
