Well, i did a search and found that i could improve the battery power with the ground wires in the engine bay. So i went out today and bought all the things i need like terminals, 4 and 8 gauge wires, and a distrub. box.
I replaced most of the factory wirings. I did the 2 on the driver side shaft (1 to engine and 1 to I believe the transmission, correct me if i'm wrong) and 1 on the passenger side which leads to the front of the engine (couldn't get the damn back one loose, will try again sometime later). I didn't have the chance to wire up from the dist. box to the alt. or anything else yet.
My question is though that when i started the car up, the lights seemed a bit brighter, which meant that i did something right, but still the gauges i have still dim when i use the power windows and other electronical things inside the car. It doesn't dim at idle though (it used to). Any help?
Thanks
Thanks
