1 - 3 of 3 Posts
I have a 1986 4x4 man trans. Looking at shop manual it says 75w-90 for transfer and trans and 80w-90 for differentials. Owners manual says 75w-90 for everything. Anyone with changing experience, would appreciate your input.
Also had oils changed 7 years ago and do not know what they used so I cannot just add because might be a different viscosity, so I am thinking I have to purge and refill each one
Thanks
Jim
If low level, you can add any correct spec fluid even if it was a different brand/viscosity used before.
Gear oil needs to be a GL5 or better for the diff. Whether its a 75w90, 80w90, sae90..... 75w110, 75w140... depends on the load you put on it and any known pre-engineered defects, while referencing the weather.
The manual transmission would benefit from a GL4 75w90. Amsoil MTG, Ford XTM5QS, and Redline MT90 are great choices.
The transfer case can take either.
Top off now and drain/refill after you order some quality fluids.
1 - 3 of 3 Posts
