look up past threads about cleaning the neutral safety switch...that's your problem....
yeah i have thew same problem with the door lights.. mine only turns on when the front two doors open.. but when i open the back doors the light stays off thus my doors can be opened through the back without the alarm going off...
and the gear shifting light also has a problem when i put it on drive.. other than that it works fine.. might say its the bulb...
try smacking the damn thing lolz it worked for mine =]
mine doesnt come on any at all, only the map lights work. but i'm gonna buy another bulb to see if it makes a difference.hmm.. then im not sure why it has doordings on the rear doors.... the dome light doesnt come on when i open the rear doors...
x2hmm gonna try that
on the contrary, went fiddling around last night and with the doors open, i pressed one of the a/c control buttons by accident, and lo and behold, the door light came on. and note, it also came on when the rear doors were open.
indeed "odd"! they are the button type. i was really wiping off that area while i was cleaning the car and i accidentally pressed one of the fan speed buttons. think the car needs an electrical check.what a odd way to find out they work!! lolz
what exactly did you do??? haha is your ac controls the button type??
the last time the light was working... yeah it did.icic .. so it does turn on when i the rear doors open
