1 - 20 of 21 Posts
'96 Camry XLE
Not sure if anyone could use this, but it is a compile of the Gen 2-5 Camry bulbs for the car.
Gen 1
1984 TOYOTA Camry
Low beam headlamp
H4656
H4656LL
High beam headlamp
H4651
Parking light
1156
1156LL
Front turn signal
1156
1156LL
Rear turn signal
1156
1156LL
Tail light
1157
1157LL
Stop light
1157
1157LL
License plate
89
Instrument-general
194
194LL
Gen 2:
1991 TOYOTA Camry
High & low beam headlamp
9004
9004LL
Parking light
168
Front turn signal
1156
1156LL
Rear turn signal
1156
1156LL
Tail light
1157
1157LL
Stop light
1157
1157LL
High mount stop light
1156
1156LL
License plate
89
Back up light
1156
1156LL
Front sidemarker
194
194LL
Rear sidemarker
194
194LL
Glove box
161
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
194
194LL
DE3022
Gen 3.0:
1992 TOYOTA Camry
Low beam headlamp
9006
9006LL
High beam headlamp
9005
Parking light
1157
1157LL
Front turn signal
1156
1156LL
Rear turn signal
1156
1156LL
Tail light
1157
1157LL
Stop light
1157
1157LL
1156
1156LL
License plate
194
194LL
Back up light
1156
1156LL
Front sidemarker
194
194LL
Rear sidemarker
194
194LL
Dome light
DE3175
Instrument-general
194
194LL
Gen 3.5:
1996 TOYOTA Camry
Low beam headlamp
9006
9006LL Long
High beam headlamp
9005
Parking light
168
Front turn signal
1156
1156LL
Rear turn signal
1156
1156LL
Tail light
1157
1157LL
Stop light
1157
1157LL
921
921LL
License plate
168
Back up light
1156
1156LL
Front sidemarker
168
Rear sidemarker
168
Glove box
74
Map light
67
Dome light
DE3022
DE3175
Step/Courtesy light
194
194LL
DE3021
DE3175
Trunk/Cargo area
DE3021
DE3022
Instrument-general
194
194LL
74
Gen 4.0:
1997 TOYOTA Camry
9003
Parking light
1157A
1157ALL
Front turn signal
1157A
1157ALL
Rear turn signal
3156
3156LL
Tail light
3157
3157LL
904
Stop light
3157
3157LL
921
921LL
License plate
2825
Back up light
921
921LL
Front sidemarker
1157A
1157ALL
Rear sidemarker
194
194LL
Glove box
37
Dome light
DE3175
Step/Courtesy light
DE3021
DE3175
Trunk/Cargo area
194
194LL
Instrument-general
194
194LL
74
Gen 4.5:
2001 TOYOTA Camry
Low beam headlamp
9006 l
9006LL
High beam headlamp
9005
Parking light
3157A
3157NALL
Front turn signal
3157A
3157NALL
Rear turn signal
3156
3156LL
Tail light
3157
3157LL
Stop light
3157
3157LL
921
921LL
License plate
2825
Back up light
921
921LL
Front sidemarker
3157A
3157NALL
Rear sidemarker
194
194LL
Glove box
37
Dome light
DE3175
Step/Courtesy light
DE3021
DE3175
Trunk/Cargo area
194
194LL
Instrument-general
194
194LL
74
Gen 5.0:
2002 TOYOTA Camry
Low beam headlamp
9006
9006LL
High beam headlamp
9005
Parking light
3457LL
Front turn signal
3457LL
Rear turn signal
921
921LL
Tail light
3057
3057LL
Stop light
3057
3057LL
921
921LL
Fog/Driving light
9006
9006LL
License plate
2825
Back up light
921
921LL
Front sidemarker
3457LL
Rear sidemarker
194
194LL
Glove box
168
Map light
168
Dome light
DE3175
DE3423
Trunk/Cargo area
168
DE3021
Gen 5.5:
2005 TOYOTA Camry
Low beam headlamp
9006
9006LL
High beam headlamp
9005
Parking light
2825
Front turn signal
4157LL
Rear turn signal
4157LL
Tail light
3157
3157LL
7443
Stop light
3157
3157LL
7443
921
921LL
Fog/Driving light
9006
9006LL
License plate
2825
Back up light
921
921LL
Front sidemarker
2825
Rear sidemarker
2825
Glove box
168
Map light
168
Dome light
DE3022
DE3175
Trunk/Cargo area
168
DE3021
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide
Info added from other awsome TNers:
touringcamry said:
Couple things I discovered recently.
3057 and 3157 bulbs can be replaced with 3457 bulbs. The base is the same but the 3457 bulbs are slightly brighter. The increse in power used negligible - approx 2.1A vs 2.2A. You can brighten up slightly
2825, 168, and 194 bulbs all share the same base but different brightness. 2825 is the brightest and 194 is the dimmest.
Camry
Good effort, but your compilation leaves a lot to be desired. Gen 3 and 3.5 use different head lamp bulbs as does Gen 4 and 4.5. Gen 5 unlike Gen 5.5 doesn't have a separate parking and turn signal lamp up front.
It looks like you just copied this off the Sylvania web site or search so you probably can remove some of their alternatives. ie, just put 9006 bulb instead of 9006XV or 9006ST. If there's an A at the end, it might be an indicator for a red or amber bulb though.
HID/Retrofit Expert
2002 Camry LE
Agreed... this doesn't encompass all of the Gens... you don't have a Gen 3, only 3.5. You don't have a Gen 4, only 4.5. And you don't have a Gen 5, only 5.5. Many of the bulbs are different between the two parts of each Gen, and many aren't even listed in the Sylvania website.
'96 Camry XLE
Does that look better? I added the .0 Gen's to the .5's and removed the other crap. :thumbup:
HID/Retrofit Expert
2002 Camry LE
You can remove the "LL" from the bulbs too... thats another Sylvania promotional acronym there for their "long-life" bulbs.
VeeZed
1988 Toyota Camry V6
Come on peeps..stop bashing him...he made the effort to get this up for us...so lets thank him a bit.
THANKS!
:D
'96 Camry XLE
Discussion Starter #11
JMSinMD said:
Why not just include the link for sylvania.com where you copy and pasted the information from? Jon.
Done
Zandro said:
what about puting in pics of the bulbs?
that would help.
Will do when I get a chunk of spare time :thumbup:
The Other White Meat
Holden Apollo
what about oversas models? we got H4/HB3 bulbs here.
Camry
THANKS!
:D
I'm not bashing him. It's constructive criticism. It's great that he's posting all this, but it's also important that he posts good accurate information.
Turn that shit up!
'85 and '86 Camries have different lights than the '84 and '83. I guess it's kind of like a gen 1.5, but the only real difference is more/different lights. Just letting you know :)
'96 Camry XLE
Discussion Starter #18
Thanks! :thumbup:
I'll fix that int he next couple day.
Camry
Banned
Camry / 2WD Pickup
Sticky!
ASG did a good thing here for the rest of us.
Please make this thread a sticky!
1 - 20 of 21 Posts
