Guys,
Help! I got this strange issue about my cooling system. Car runs find. Plenty of power. When the car is moving, car is running fine. The wierd part is when it idles, it starts to get hot. The temp guage starts to move up. It got so close to H the other day I was going McD's drive thru. I ended up turning the heater on full blast and it seems to hold the temop between normal and High.
After I left the drive thru, the temp went back down to normal. What's the problem? I'm scared that I maybe causing more damage if I keep gambling like this without fixing it. I very worried I may have a blown head gasket. I engine had a valve job about 5k miles ago.
Lastly, I went to purchase new tires for my Gen 3 Camry and Sears mentioned that I needed a camber kit to correct the alignment problem. It pulls to the left. I want to fix this before I start shredding my tires. Where do I get a camber kit and how much do they usually cost?
Please advise.
Thanks,
Harry
93 Gen 3 Camry V6 SE 5 SPD
Please advise.
Thanks,
Harry
