Yes, the harness is there, but you will have to buy the 'stalk'.....seems like they wanted over $100 for it at the dealer. I put in a PILOT AUTOMOTIVE kit that comes with almost everything. (Wiring, relay, lamps, and lighted rocker switch) If you get it, you'll have to dremel out the holes for the lamps. Look on the inside of the bumper, and you'll see an outline for the hole. What I did was just follow the FLAT part on the outside of the bumper (Recessed area) making little adjustments afterward to insure a tight/factory looking fit. I also made some "L" brackets to hang the lamps from to secure them in place. (Theres a hole in the frame directly above the lamp to bolt the bracket to.) I scuffed up the inside of the bumper, and the lamp housing and put epoxy around them on the inside, then used marine grade silicone (Non-yellowing) to put a bead around them on the the outside to keep out water. They look and work great, and I have not had any problem with them for over a year now. DO NOT BUY FROM AUTOTRIX!!! Absolute A holes!!! Wont back product etc....Insisted that all '03 LE Camry's have the holes already in the bumper (Like I cant see my own car) Sent me pictures of a corolla front end.... Punk on the phone (Customer service) actually said "Funny, we have lots of GIRL customers and THEY can put them on without cutting anything".....Ahhh!!!Sorry for the rant.
MCTOY
