i got an 2003 camry se v6 drop with eibach spring, currently i am riding on 18inch with 225-40-18, i would like to know what other size tire i can use and won't cause any problem or rub, i would like something more thicker then the low profile tire
We normally use 225 45 18 on the car but this is with standard suspension. This would add about 1 inch in overall diameter compared to the 225 40 so roughly 1/2 inch above and below the axle. You'll have to take some measurements with current tire to confirm clearance. You can search by size at following: Tires
1 - 2 of 2 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
