1 - 6 of 6 Posts
I'm getting a 96 camry with 144k on the dash. Wondering what I should do.
oil change?
trans fluid change? if so, what oil do i get? [its an automatic]
just wanna get this baby on the reliable path. i go to school full time and work 35 hours a week if not more.
Camry Expert/MR2 JR Xpert
MR2 & 96 V6 Cam
AWESOME!!!! :welcome: to the Gen 3.5 Club...:lol:
EDIT: woah woah woah...before all of this on the list...what powerplant are you running?
1. Flush all fluids. (oil, trans, differential, brake, p/s, coolant)
2. Change fuel filter
3. Change air filter,
4. Change PCV Valve
5. Clean Throttle w/ Seafoam Deep Creep
6. Seafoam a vacuum hose
7. Check brake pads/rotors
8. Check fuses/ bulbs
9. Check Tires
10. Check Dog Bone for damage
11. Check other engine mounts
12. Check axles
13. Check ball joints/tie rod ends/stabilizer links/rsb bushings
14. Clean engine bay/ interior/exterior
15. Buy your favorite Little Tree
16. Put on shades (if you dont have any then buy some)
17. Ride in 1996 Style...
Thats a good place to start :thumbsup:
MR2 & 96 V6 Cam
PCV valve is right on top of the valve cover...it has a hose leading to the intake manifold...
Discussion Starter · #5 ·
im going to be tearing the streets up with the 500 hp 2.2 4 cylinder. its front wheel drive so that drops the power to about 150hp tho.
and i dunno when the timing belt has been done. probably never
MR2 & 96 V6 Cam
More like 100whp...:lol:
Then add:
1.Timing Belt
2.Idler/tentioner
3.Water Pump
4.Oil Pump gasket
This takes a bit more tech skills. I would say unless youre a mechanic or have a good understanding of timing then I wouldnt DIY...
1 - 6 of 6 Posts
