1 - 11 of 11 Posts
Just pin it, Ya' fairy!
08 tacoma
rear lift is achieved by either aal, block or a new leaf pack, the rear 5100's are just shock with better valving then stock
2006 Silver Dbl Cab
Did your first post have a question or were you just stating that that is a good idea?
No, rear shocks do not add any lift. If you do the Toyotec AAL with the TSB springs, then you will definitely want to set the front 5100s to 2.5.
GO KING'S GO!
05' Taco Pre-Runner
Blistine 5100's front with 2.5 lift and rear with aal on the tsb springs
If this is a question then yes that is a good idea.
5100'-set @ 2.5"
Rear AAL-2" for your tsb springs
Then get an alignment and you are golden! :thumbsup:
Discussion Starter #6
thanks if i stick with the tsb leafs and put the 5100 to 2.5 at front will that be level? also if i put 265/75/16 bfg all terrains will i need to remove my front mud flaps
08 tacoma
no you will be high in the front if you have the tsb leafs set the billies at 1.75 (the second notch from the bottom) and you will be close to level. 265/75/16 you will not need to remove your front mudflaps or do any trimming.
Stupid is stupid does
2008 tundra
to the OP: :headbang: please take the time to post correctly.
Russolini
i already have the bilsteins nd the rear tsb, but im looking for a little extra and considering this same setup. shocks are at 175 right now so ill have them adjusted to 250 and get the toytec aal for the tsb.
my question is, is it a good idea then to get wheel spacers since the front wheels will kind of be brought in a little more? or does that not happen, i kind of want them anyway since it should sit a little wider and more aggresive. thoughts?
GO KING'S GO!
05' Taco Pre-Runner
wont the aals on the tsb make it stiffer?
Yes, but it feels like a real truck now. Plus if you haul or tow you will want them. Lastly you get less axel wrap and body roll...it makes the truck very tight! :thumbsup:
1 - 11 of 11 Posts
